I started my 351 ford 235 omc outdrive at the house with the hose hooked up, ran great. ( no cooling problems ) took it to the lake and it ran well. but after about 10 min the heat gauge started to rise at low speed. So I gave it some gas and it came down to normal, thought it was going to be OK but then it started to rise again at all speeds so I turned it off. Do you think the impeller is bad or what?
