Re: Ford 460 rebuild cam question
can't knock cheap as far as I'm concerned... of course it has to be the right part but a micrometer and a googling of part numbers can probably verify what's coming out of the 460....
I was recommending searching because in the last discussion, we discovered the $75 cam was the same as the one coming out that had given good service as I recall..
Summit has a marine COMP brand cam for $126... might be the same one discussed last time, worth checking to see if it matches the one that came out in profile and specs...
"COMP Cams Xtreme Marine Camshafts
Camshaft, Hydraulic Flat Tappet, Advertised Duration 262/ 268, Lift .514/ .524, Ford, Big Block"
