Irishbrannan
- Joined
- Nov 2, 2015
- 6
Hi, I have a 1994 bayliner with the 3.0/alpha gen 2. I' want to swap it out for a ford 302 I built with marine parts. I'm also changing the gear ratios and whatever else I need (interrupt switch etc) I'm not running water loggers also. I know that a ford bellhousing to alpha transom plate doesn't exist but I hear an mc-1 transom plate will adapt to a alpha? I can get the mc-1 plate and bellhousing for cheap. I also hear the ford engine coupler has same splines as alpha drive. Any one know if this will work?
