55evinrude
- Joined
- Apr 11, 2011
- 252
well i was just looking at the manual and it say to crank the motor a few revolutions with the ignition system disabled to clear water out of the impeller housing, do i really need to do this?
I filled the hose from the impeller housing to the t-stat with AF and than drained the hose also pulled the hose from the drive going to the housing, but im worried there is water still trapped between the impeller fins that could freeze. so if i do need to drain this can i just take the housing off and drain into bilge as cranking the motor at this point is no option. thanks
Nathan
Nathan
