ok after previously putting in new steering cable and having a days fishing with no drama,i have just gone and hung all wires & cables up out of the way,did have a minor problem with tilt/trim which i fixed by a light sanding on points in fuse box,went to start motor but didnt start as looked like starter motor wouldnt engage flywheel,now after moving gears to reverse it is stuck wont get neutral or forward,released all wiring that was tucked away in case but to no avail.any ideas?motor is a johnson 1978 115hp etz,cheers
