Matthew A.
- Joined
- Jan 24, 2006
- 232
According to the HSG number stamped on the lower unit housing [assuming the location of the stamped number is under the oil fill plug] the foward gear should have a minimum of .008" of shim material under the forward gears roller bearing "outer race". Upon pulling the "outer race" from the lower unit, to my surprise, there was no shims under the outer race. There were however, shims located under the foward gears roller bearings "inner race" between the bearing and the gear itself. None of the manuals I have read mention the possibility of finding shim material under the inner race sandwhiched between the gear and the bearing. The forward gear does not have a location where a number or letter has been stamped. There is however a raised mark on the side of the gear that appears to resemmble the number 5 or possibly the letter S. Because of the stamp code on the housing dictates there must be a minimum of .008" of shim material under the "outer race" regardless of the code stamped on the gear, and there were no shims under the "outer race"; and because there was shim material where no manuals say there maybe shims, I am unclear on how to determine whether or not any shim material should be used and where those shims need to be placed. Any one have any ideas on what to do and possibly how to do it? Also, the manual says the center bearing carriers needle bearing is not replaceable and the carrier w/bearing can only be had as one unit. I have a new torrington needle bearing that the carrier requires. Is there a specific reason why I cannot or should not press out the old bearing and install the new one I have and must replace both carrier and bearing as one unit?
