Forward is reverse and reverse is forward I need help
reganjr
replace my water pump and removed my prop , put thing back together what did I miss 1992 mercury 50 hp outboard .I have idea but want input before starting thanks
Common problem.----Top of the page is the tutorial under ----SHIFTSHAFT SETUP----Start with removing the lower unit again.----You have to make sure that both lower and control box are the same just before sliding the works together !!
GA_Boater
Is this a skills test for us? :confused:
What is your idea? I have an idea too, but you first.
reganjr
I was thinking shift shaft rotation and did not mean to question anyones knowledge or skills . thanks for your input
reganjr
Hey forward is forward and reverse is reverse back to normal thanks for rthe help also adjusted lever
