Fouled a pug about two miles from boat launch. I ran the boat on to the ramp the loaded it up. ( went slow )will this damage a two stroke? its a carb engine.
most likely not. on a four stroke it would lead to oil dilution and washing the lube off the cyl walls. a two stoke has the lube mixed with the fuel. it will make a mess in your driveway when you tilt it down
