Sea Rider
- Joined
- Sep 20, 2008
- 12,345
This is a 2 stroke Tohatsu 18 HP motor with around 150 worked hours, exhaust covers and chambers, cylinder head as in (2), pistons were impeccable decarboned and cleaned to mint condition as in (2) on last full restoration. Due to achieving poor acceleration when opening up the throttle fast decided to remove the cylinder head assuming was having water intrusion in the combustion chambers, but when removed found this awful scenario. Data : The owner uses a cheap 2 stroke uncertified TCW-3 oil mixed at 50 : 1 and run at low to medium speeds on daily basis powering a medium size boat used as as a work boat and tender. Know that on 2 strokes 2 cylinder motors cylinders does not carbon up same, usually it's one or the other, but this one is the worse seen. Assume it's a combo of poor oil quality + long slow revving ?
New NGK spark plugs were well gaped to specs, all gaskets were installed brand new and torqued to specs and the time advance/carb perfectly synched. Ideas, tech wild guessings that accounts for such scenario ?
Happy Boating
Happy Boating
