Here's the quick story. Bought the boat 2001 ProSport with 150 Mercury Carbed outboard this year from dealer. Finding things left and right wrong it. Needless to say I'm upset, but it is what it is. I bought her with a half tank, but filled her up with high octane and have kept her full all year. I decided to run the gas tank down to a low level and then fill her up with high octane for storage. Well, I got her down to just under half a tank and she started stalling. Couldn't get her running. After a tow back, I started looking her over.
I started with the fuel pump to see if that was the issue. I took off the hose and cranked the engine, sure enough gas was flowing so that wasn't the problem. I caught the gas in a mason jar to check it out. The gas on the left is from the boat, the gas on the right is how it should look (2 cycle). I'm guessing the good gas I put in this year was enough to keep her running, but once that burned off, the jar on the right is what is left.
I'm guessing the boat has set for a few years before I got it. Anyone seen anything like this? What do I do now? I can syphon it out, but......
*What do I do with all that gas?
*I'm sure there will be sludge in the tank. I cannot remove the tank as it's below deck, so what do I do?
*Anything else I should clean up before I run her again.
Thanks to all for help.
