1979SeaRay
- Joined
- Jul 31, 2005
- 14
I use my boat primarily for fishing and do a lot of trolling at low speeds, typically 1-2mph. I usually run NGK in my Mercruiser 898 Chevy 305 and recently changed the plugs to Champion RV8C which is all the Marina had in stock. I only ran the pulgs for two outings and during the first one the boat ran really nice. On the second outing after a troll I had bogging down problems and limped back to shore. After doing fuel pressure and vaccum tests I pulled the plugs and noticed they were all fouled up. Black soot-carbon buildup. I realize trolling for long periods of time will create carbon buildup but this seems a little excessive after only two outings.
Any thoughts on what is causing the plugs to foul up so quickly? I didnt think the Mercruiser engines were as succeptable to carbon buildup as much as an outboard, and I never had a problem this bad before I changed the plugs. Is it possible the Champion plug is not running hot enough? I do have an electronc ignition converted from points. I also had gas on the plugs when I pulled them.
