Fouled spark plugs...weak coil?
Picknasty
I just changed the spark plugs on my 1996 OMC 7.4GL inboard. This is the first time the plugs (ACDelco MR43T) have been changed since I purchased the boat in January. When I pulled the plugs I inspected each closely and found that all were fouled with carbon deposits and one had a little oil film on it. After looking at a few burn charts I see that fouling is typical of a plug that hasn't reached the optimum burn temp of 450 degrees and/or a maladjusted carb. Would I be right to replace my ignition coil and seeing what that does before rebuilding/adjusting my carb?
Maybe I'm trying to do too much to fix this issue but I'm just trying to do the best preventative maintenance I can to make this engine last. Having said all this, fire away and let me know what you guys think. Thanks!
Ayuh,.... Welcome Aboard,..... Changin' the coil ain't gonna fix the carb,....
Picknasty
So this is predominately a carb issue? Should I be looking to rebuild or adjust? If so what exactly am I looking at getting into? Thanks
Ayuh,.... Probably a 99% chance,....
Adjustin' might do it, but a full on rebuild, 'n set-up for sure oughta fix it,....
Picknasty
Sounds good, I'll look to rebuild it after the season then. Its running great now, just looking ahead and performing the right maintenance. Thanks again.
