jerryjerry05
- Joined
- May 7, 2008
- 18,158
About a 1982 50hp. 4 cy. Ser#5951619
Has good comp on all 4 about 150-155
Good spark on all 4
I can change the plugs and the problem stays on #3
The reeds are ok.
The carbs spotless.
The fuel pump diaphragms both OK.
Starts and runs poorly.
The 3rd cyl. from the top carbons up real bad after a couple of min running.
The air screws are real hard to get anywhere close????
I don't see any blow back through the carbs.
Is it possible something in the exhaust chest has let loose?
Thanks,J
Good spark on all 4
The reeds are ok.
The carbs spotless.
Thanks,J
