biglurr54
- Joined
- Feb 14, 2011
- 234
My 1989 Evinrude120 VRO looper has been running rough at idle. I live on a small lake and usually have the motor idling while we putt around the lake drinking beverages. I have never decarboned the motor so i bought some Seafoam Deep Creep and went to it. I warmed the motor up and pulled the Air Box off the carbs. The Air Box had a layer of oil in the bottom of the air box. I would say about 4-5oz of red oil. I have only used Evinrude XD-30 oil which is red. Judging by the gasket at the bottom of the air box this is normal but I was not sure. Is this normal? I have disconnected the VRO and pre mix all my gas and use mid grade gas treated with stabil marine. I am going to start using seafoam in every other tank to keep carbon at a minimum. The motor has very low hours but it is an older motor. The carbs have never been touched. I have never adjusted anything on the motor for fuel to air mixture. Right now the motor is marinating in Deep Creep. I plan to run it all out tomorrow and put new plugs in (still has the originals). Im hoping that will help with the idle issues. Any advice on either the idling issue or oil in the air box will be greatly appreciated.
Also the boat now sits at a dock in the water all summer, if that helps diagnose the oil issue.
