Found rotten wood
Jakem
As I was installing a swim grid I found on one side of my transom rotten wood were my tie down hook is( wich was loose). I can access the wood from the inside to do the repair. The outside fiberglass of the transom is solid. Here is a pic from inside boat...any suggestions appreciate
tpenfield
My suggestion is to scope out the area and get going with cutting and gutting. Usually the bad stuff goes about 5 times further than what you initially think/hope.
Jakem
So remove outdrive and transom assembly and cut my way in?
tpenfield
Read through some of the restoration threads to get an idea of how folks have done it in the past. Each restoration is unique, but you will see the common approaches by reading through some threads of those who have gone before you.
A few pictures from further back will help with responses.
Jakem
It's wet yes and also some dry rot...I will get more pics
airshot
Probably easier to work on with the engine out of the way....not gonna be a quick and simple job !
Jakem
Right...I've become good at yanking that out lol so no biggie there
JASinIL2006
That is pretty similar to how I discovered rot in my transom, except it was my ladder bolts that were loose. I ended up replacing the transom, most of the deck and all of the flotation foam. Luckily, my stringers were made of fiberglass, so they did not need to be replaced. If you click the link in my signature, you can see what you might be in store for.
Jakem
I couldn't seem to find a link?
JASinIL2006
Here you go!
