Firstly thanks very much to the knowledgeable regulars here who helped me get my engine pulled on my way to repalcing my holed oil pan and some other rusty components. Well, that's the good news....
<br /><br />Long story short, I think this is not worth my time, and I might do better to find a complete reman on ebay and just drop it in, while parting out whats salvageable of the 1988 7.4L that I have.<br /><br />Here is the situation, what I would like feedback on mostly is if this is worth my time as a beginner mechanic who can't afford to just take it down to the local shady guy and say "fix whatever needs fixin'!" when it IS within my means to spend 2500-3000 to start fresh and drop in a complete moderately used engine from a repower or something of the like and just be done with it. (sorry that was a damn long sentence). <br /><br />THis is what I have found to lead me to my current discouraged state: <br /><br />1. Removed exhuast manifolds and risers, found water passages to be about 50% clogged and everything past the elbow to be covered in a rusty coating, however, it looked like there was plenty of metal, ie, the rust deposits were coming from somplace else. It was so bad I initially thought I spaced somewhere when winterizing and everything was filled with ICE.... but it didn't melt when I took it inside.<br /><br />2. Removed thermostat assembly and the inside of the intake manifold is NASTY rusty...this is the first one I've seen so I have nothing to compare to, but I can't think this is normal rusty. <br /><br />3. Moved some bolts around on the intake to relocate the lifting eye and they came out WET and smelling like sulphur (like MUD I think....?). I assume not good. <br /><br />4. Finally got at oil pan but at least 4 of the bolt's heads disintegrated when I tried to unscrew them. They did not crumble completely but rounded off with very little effort. I stopped. <br /><br />5. And the thing that drove me to start drinking: One bolt on each front engine mount I thought was "missing" and needed to be replaced, in fact was broken off by the previous owner (apparently) and I couldn't tell until I lifted the motor off the mounts and got a light in there. <br /><br />SO - s*** can the whole thing and start over? Or risk taking it in to the "pro's", to piece it back to health, who around here I am not trusting of. <br /><br />One last thing, this engine ran last summer, and really pretty well at that. I wanted only to fix the leaking oil pan to get rid of the oil waste/pollution and replace a few of the rustiest looking parts. Instead, it looks (to me) like I have uncovered a time bomb. Is it as bad I think?
<br /><br />Thanks for reading this far,<br />Mike.<br /><br />BTW, you guys see the new iboats homepage? slick!
