Re: Found the problem..now how do I test it ???
I have the same motor. I see in another thread your compression looks pretty good, so I agree that DVA checks on ignition components are the place to go next. I use this device on a basic Harbor Freight DVM:
ESI 640 Electronic Specialties 640 DVA Adapter
But let me ask, do you see any sign of water intrusion into the #3 cylinder (say, emulsified oily/watery wet fouling on the plug, or corrosion on the firing end)? Do you get a lot of nasty snotty-looking exhaust junk out the thru-prop exhaust? Is this something that just suddenly began, or have you had progressing issues with it (like over time, getting harder and harder to start, lugs more and more, etc.)?
Has this motor seen a lot of saltwater running? I see in another post that your rear water jacket is leaking, indicative of corrosion inside the water jackets. There is a baffle between the exhaust and the water jacket on the port side of the engine that, once it corrodes through (and it will eventually, far faster in salt), puts water into #3 cylinder. Ask me and my replacement powerhead how I know all this :grumpy:
