found this in my bilge what is it?
Tailguner
i found this in my bilge while cleaning it. its a pin of some sort and the end of it flips over 90 degrees as if to hold something. My engine is a 7.4 merc fuel injected with a Bravo 3 drive on a Sea Ray 230 BR signature. does anyone know what this is???? I dont even know if it came from the engine or drive it could have come from something else and got washed into the bilge....:eek:
rbh
Re: found this in my bilge what is it?
Pin for the bimini mounts????
dubs283
i agree with rbh
pin for bimini top or doghouse hinge??
i have never seen a pin like that on a mercruiser engine or drive
Danny Mc
It appears to be bout 5/16 or 3/8in, too big for bimini, prolly for eng cover tho I have never seen any like that. For sure never seen one anywhere on a drive
Tailguner
it could be... i dont even know if it came from this boat.... i did check and this pin will not fit thru any of the bimini mounts on the boat....:cool:
sea flower
looks like something from your steering linkage
paultjohnson
Are they hollow, as in, could fluid flow thru them.? Especially the 2nd one [without the 90 deg piece ] Are they the same size? one doesnt fit inside the other does it ?:confused: I mean like the part with the diamond? grip texture. does that snug up into the hole on the other male -female?
paultjohnson
Duh its the same piece photod twice took me a sec to see that on my crap screen dunno what it is
jaxnjil
its either the pin for the engine door hinge or the the pin that holds the back seat hing to the transom
ours uses them in both spots
bitterboater
Looks a bit like a hitch pin from a receiver hitch.
86 century
Ensign
If you have young kids around look at your lawn mower or leaf blower my young en loves to help by brining dad all sorts of unrelated part to confuse me. Good Luck
reelfishin
It looks like the pin that holds my transom saver on my frame. You slide it through the hole and flip the end over to hold it in place. Mine is about 5/16" in diameter or so.
paultjohnson
its obviosley a left handed plated rempestex harxflep plendum attaching craderspink holer skich... I think.... maybe its right handed ... I cant see the angle of clanker splot-shaft :)
Challenger84
Ahahaha too funny.
BTW I'm really diggin the color scheme on your boat!
Philster
And here I thought it was a Johnson rod used to adjust muffler bearings.
royal0014
Waitaminute, didn't we just have a muffler bearing thread? :rolleyes:
Jeep Man
You spelled "obviously" incorrectly. Otherwise, your spot on.:)
