Four Stroke Question
Snake334
I have a 2015 Mercury 150 four stroke. It has approx 20 to 30 hours on it. The other day, I noticed when I started the engine, it shot out black soot looking stuff from the upper exhaust / relief port. It only done it during start-up and I only noticed it 3 or 4 times over several days. The engine started normally and ran great. It made no strange noises or anything odd. I use a combination of 100% gasoline and 10% ethanol gas. I also use Stabil in every fill up. My question is, is this normal or is it a sign of a problem.?
all motors need to run rich when you first start them. when they run rich, they generate a bit of soot.
no need to use stabil every fill up if you boat often
Snake334
Thanks for the response. When we purchased the boat, the dealer said the Stabil was a recommendation from Mercury on their new engines. Use at every fill up, 1oz per 10 gallons.
