Re: Four Winns O/B owners need some help
It seems a data point is wrong somewhere??
I found a resource that says your outdrive ratio is 2 to 1. Can you or anyone confirm true or false?
If true...
Prop calculator says you have a theoretical top speed of 49 mph at 5,500 rpms. If you are only getting 32 that means you have a whopping 35% slip! That is so poor it is essentially unrealistic.
This means at least one of the following figures is absolutely incorrect:
Pitch
RPM
Speed
Drive ratio
I have no idea which data point(s) causing the problem.
Can you confirm your tach is set correctly and reading correctly? I suspect a possible error here, assuming your GPS was reading speed correctly.
And if I am wrong about drive ratio, then my comments here are of no value. Can anyone cofirm?
