A few months ago I purchased a 2004 Four Winns Horizon 190 with only 80 hours and a Volvo-Pento 5.0 GXi with an SX outdrive configured with a stock 14.25" x 21 pitch aluminum prop. Immediately after purchasing the boat I took it to my local Four Winns dealer for a complete tune-up and inspection and was cleared to go. I took the boat out on the lake today with about a half tank of gas, four adults and loaded up for fun. The lake's surface elevation is 550 feet and the waters were calm. The boat seems surprisingly sluggish out of the hole and with WOT was only pulling 4200 RPM at 45 MPH (as measured by the boat's spedometer). Generally I want to use the boat for family fun and will likely be heavily loaded with 6 or so people most times. I intend to pull the kids around on the lake on an inflatable and pull an occasional wakeboarder. I really don't care that much about top speed compared to better hole shot and more appropriate RPMs at WOT. Finally, I will be running the boat at two lakes with very different elevations (one at 550 feet and the other at 5500 feet), so I likely need two props... so I'm probably looking at aluminim instead of SS just to save some money. With all that said, I'm looking for some general prop advice, etc. Also-
1. Will a 4 blade prop meet my needs better than a 3 blade prop at either lake? I figure the 4 blade will help with hole shot and getting on plane sooner.
2. Given the low RPMs with my somewhat unscientific test today, and provided I go to a 4 blade prop, what pitch do you recomend? I'm thinking something like 18 pitch at 550 feet and about 16 pitch at 5500 feet.
3. Should I stick the the Volvo-Penta brand prop or look at something aftermarket?
Any and all comments will be welcomed and appreciated. Thanks.
