metriccrescentwrench
- Joined
- Oct 22, 2007
- 2,598
I'd avoided using names before, worried that I might be breaking forum rules. I just reread the rules and they state that as long as I strictly stick to facts that I can post my experiences about a vendor.
It turns out that SparkieBoat and I both got ripped off by the same guy - Frank Mathews on Wilmington Island near Savannah, GA.
Sparkie recently bought what was purported to be a rebuilt engine when in fact it was cobbled together and not nearly what was claimed. Here's his thread with some photos.
http://forums.iboats.com/forumdisplay.php?f=24
A couple of years ago I bought what I thought was an engine in good working order from Frank Mathews for the Checkmate I was rebuilding. He claimed that the powerhead only had a few hours on it, and the lower unit/water pump were recently serviced. 6 months after I bought the engine I mounted it on my Checkmate and found:
1. The cooling system had been cobbled together. The water control valve was removed and the water line that should have been going to that simply went to the pisser. The engine would only run in the lake for about 5 minutes like that before overheating. (Thanks to Faztbullet I got the cooling figured out.)
2. Two of the bearing housing bolts beneath the water pump were broken off, which resulted in gear lube leaking out and water getting into the gearcase.
3. Two carb bodies were cracked.
4. For some reason there were two head gaskets on the starboard side. They were old ones which were reused.
5. There is mild scoring inside a couple of cylinders. Definitely more than just a few hours on the powerhead.
6. Bad timer base.
7. Cracked flywheel magnet.
8. Instead of recirc valves plain barbed fittings were used.
9. Instead of replacing worn out reeds they were simply flipped over. Installing new reeds significantly improved the idle.
EDIT to add: After tearing the engine down I found that one of the pistons was cracked. Additionally I found a couple of the connecting rod bearings to be discolored.
So it seems that Frank Mathews has been doing the same thing for quite some time. I'm hoping that I can keep even one person from getting ripped off by him.
6. Bad timer base.
