Fl_Richard
- Joined
- Jan 21, 2005
- 1,428
Reading an article on the Johnson repair board about Wyraps made me remember this tip, and I thought I would share.
When you cut a Tywrap with wire cutters or diagonal cutters (dikes) if you cut the Tywrap by the edge it will not cut you open and make you bleed like it does if you cut it on the flat side.
This is good.....
------------- (Cutter)
l
l
l - Tywrap
l
l
This is bad.....
------------ Tywrap
------------(Cutter)
This is good.....
l
l
l - Tywrap
l
l
This is bad.....
------------ Tywrap
