ericcarr2000
Ensign
- Joined
- Mar 19, 2010
- 903
Ok, I just got done taking my boat out for the first time this year. It is a 1990 250 sundancer that used to have a 454 with 950 hours on it with a bravo 1 drive. I put a dynoed 454 motor in her with a bravo 3 drive. She idles and runs fine but when I try to get up on plane I notice that it begins to bog down and shake a bit and I can only get her to about 2200 rpms when this happens. What could be going on? On the dyno it got to 5200 rpms no problem. Could I gave s motor mount issue with the torque causing it to just slightly rise up? I made sure the motor was aligned properly before installing the drive. I did notice when I replaced the mounts that there was 1 of the 4 bolts that bolt down to the stringers was stripped out a bit.
