fresh - salt
surreyboy
hey people , first i just want to say welcome back for those of you that have been living in a freezer(like i) & the "season" is just around the corner . my question however is what do i have to do to my boat to change it from fresh water to salt water ? i will only be in salt water for about 2 weeks but it has never been in salt before & i don't want to wreck it ?????
CheapboatKev
Re: fresh - salt
Flush her..wash her down with fresh water..
Is this an I/O or OB?
I think OB's are much more resilent to salt (or easir to clean up) than I/Os
RWilson2526
Re: fresh - salt
boats arent fresh or saltwater specific...you dont have to do anything. Like the previous poster said, flush it on muffs with freshwater as soon as you have a chance but just 2 weeks worth of saltwater boating wont do any harm even if you cant flush it.....
Philster
Re: fresh - salt
Yeah, it's not like you are dropping the boat in molten lava.
Over the years, salt corrodes parts and shortens the life of different components.
You need to do the following. The last part is essential. Skip this last step and all bets are off.
1. Clean the boat.
2. Flush the engine.
3. Have a brewskie.
tnduc
Re: fresh - salt
Funny- that is exactly what some of these posts read like. My boat is 20 years old and has been used exclusively in saltwater. After every outing just wash it down, flush the motor and done. Only thing I have done is replaced a few fasteners that have corroded (about $20 in repairs).
HAV2FISH
Re: fresh - salt
If you have the opportunity to put into fresh water then run to salt when you return back to fresh this will flush the boat for you. It's also better on the trailer.
Home Cookin'
Re: fresh - salt
it won't affect your boat one bit. Be more concerned about the trailer: rinse it (hubs, axles etc) and if you can, launch and retrieve without getting the axle wet. But two events won't do anything
JoLin
Re: fresh - salt
+1
I was contemplating adding a neutra-salt system to my V-P and brought this up with my Power Squadron cronies at last week's class (marine electrical systems). I'm still thinking about it but I'll share what the others told me.
One guy is the original owner of a '92 Larson with Mercruiser I/O. All original.18 years. It sits in salt at his dock from May-Oct and gets flushed when it's hauled for the winter. The I/O is serviced annually, and he's on his 3rd set of mainfolds and risers. Says he's due to replace again in a year or 2.
The 2 other old-timers in the class run straight inboard boats, older than his, raw water cooled, still have the original power plants. Fresh water cooling? Not for my area- recommended AGAINST. Too much plant life in the Great South Bay. Sea weed and sea grass clog heat exchangers and cause overheating and boil-over. If you don't catch it in time you're sitting out there somewhere with a bilge full of anti-freeze.
I would never tell anyone that FWC is bad, but it pays to understand what others in your area are using, and why
The key to everything is regular inspection and maintenance. Yeah, salt will kill your stuff in 25 or 30 years, but odds are better that it'll die of mechanical failure first, or that the motor or drive will just be tired and ready for replacement.
My .02
mphy98
Re: fresh - salt
1. Clean the boat.
3. Have a brewskie.
I think you got the order wrong
1. Have a brewski
2. Have another brewski
3. Flush the motor
4. Have the kids clean the rest of the boat.
:D :D :D :D :D
Thajeffski
Re: fresh - salt
Aren't u supposed to use a different kind of anode metal?
robert graham
Re: fresh - salt
Wouldn't hurt to spray down your tilt/trim motor/pump and rods with white lithium grease to keep the salt water off of them. Some motors, mine included, have a plain steel(not stainless) tilt/trim motor casing which is very prone to corrosion, especially in salt water. That grease hangs on there pretty darn well, keeps it from rusting. Good Luck!
Home Cookin'
Re: fresh - salt
remeber, this guy is only going to be in salt water for 2 weeks. No need to switch stuff out, but it's good to know.
Fireman431
Re: fresh - salt
You forgot the most important thing...have a good time. These boats aren't made of crystal. Lots of years or R & D (and severe torture tests) were done long before the engine ever went into production. This was to make sure that something like 2 weeks in the salt water weren't going to destroy your boat.
Like everyone said...flush it out for 5 minutes afterward and you'll be fine.:)
