Fresh water flush
dthx
Honda 30 hp 2013 long shaft tiller no trim or tilt
question
whete is the fresh water flushing port and what is the special adapter I need if any
cant find it in my service manual
thanks
Darryl
MattFL
On the larger (40/50HP) the port is a screw hole on the side of the lower unit. But you likely don't need to use it or the special fitting, if the water inlets are on the side of the lower unit then regular old muffs will probably work fine. My 50HP has the special flush port, but I've been using muffs with it for the past 20 years without issue. Just make sure there is sufficient water flow to flood the pump.
Sea Rider
When using the lower leg flushing port with attached adapter must tape both sides of the lower leg water intakes to avoid excesive water pressure loss going up leg when flushing with muffs.
Happy Boating
