Fresh water pump 2565
high noon
The fresh water pump for sinks and showers, motor runs, but will not pump water. Fresh water tank full, lines purged of air, water runs freely from all outlets when connected to dock service inlet, Boat is new(2006). Pump worked the first time it was used to rid of Freeze ban, several days later, the above problem. Any help is appreciated.
Mischief Managed
Re: Fresh water pump 2565
Check the inlet filter on the pump, it's probably clogged. Failing that, it might need a rebuild. Most can be easiliy rebuilt.
