freshwater cooling full kits
newtoboat101
hello,new gm 5.7 vortec motor ,was trying to get aftermarket full closed cooling kit, what companies are still making kits ,monitor cooling kits are not being made until a sept 22 decision to continue production, seakamp no longer producing ,orca marine have not heard back from,cp performance hasnt gotten back to me yet dont know there brand that they sell,has anyone made there own ,buy replacement parts and fit hoses and clamps themselves thank you
kenny nunez
Whichever kit you get you will need a crankshaft driven raw water pump pulling from the bottom of the boat with a valve to close off the water should you need to service the crank driven pump. The drive pump needs to be connected with a “Y” pipe to the incoming water. This way the drive pump keeps the drive cool. This makes it easy to run the engine on a flush out.
Try Marine Power in Ponchatoula, La. They have fresh water cooling kits.
Believe me, the drive pump will not keep a heat exchanger cooled engine cool. Especially a V8.
alpha drive will only support a half system
as Kenny stated, a full system requires more flow
Most "Kits" are difficult for the Heat Exchanger OEM's as they have to buy 100 brackets and components at a crack to keep it cost effective for the end user.
so they quit making kits as most sit on the shelf collecting dust.
I make my own parts for HX kits. then again, I used to work for Champ
if you get a HX for the Mercruiser 6.2, I can sketch up the plumbing routing (or look at mid 90 volvo pentas) converting to a full kit. you would have to make your own brackets and source some parts on your own.
newtoboat101
ok so i should look for the half kit that just cools block ,because full kit with pump will not be a true full closed kit ,and not compatible with alpha 1 gen 1 ,correct?
