Question, a friend of mine didnt winterize his boat and we went out to see it today. We are in Iowa and it did snow/freeze here but hasnt been bad at all. I pulled the oul dip stick and there was no water in it, clean fresh oil. I went ahead and pulled the 2 drain plugs and fresh clear water ran out, removed the hose and bumpred it a few times to clear the water and left the plugs out as per manual specs. We didnt fill it with AF as air wont freeze..just to be safe. Pulled the spark plugs and pouted a little oil in each cylinder and bumped it, put the plugs back in. Anything else? I had mine winterized so not sure what all needs done.<br /><br />But since the oil was clean and the water was crystal clear..did he get lucky and nothing happened? I also lowered his lower unit, but we didnt do anything like drain anything..should we? Do we need to do any thing else? Thanks for the help in advance!
