Friend hooked up his battery backwards on his Lowe Sun Cruiser Jamaca 220
odie241
Hello fellow boaters,hope everyones season is going good so far.I have a friend/aquaintance that has a "2002 Lowe sun crusier jamaca 220" that has a 75hp Yamaha on it,or maybe a evenrude 75hp.Anyways,he has a problem that after he hooked up the battery backwards,he has no starting issue now.He said that it has lights and horn but nothing else.Can you give me an idea on what I need to look for when I get down there afterwork tonight.Thanks for your time,,Odie
BobGinCO
Re: Friend hooked up his battery backwards on his Lowe Sun Cruiser Jamaca 220
Lights and horn don't care which way you hook up the battery. The ECM in a motor is a lot more particular.
odie241
Is there a normal fuse panel on this boat,or am I going to be looking for some hidden fuses somewhere??
lncoop
Should be a fuse somewhere under the cowl, most likely on the same side as the electrical goodies. If he's lucky it blew before anything was fried. Start there.
lncoop
Just to clarify, I'm only talking about the outboard. House panel and accessories is an entirely different matter. Hopefully there's a main in line fuse on the house panel's positive cable. Mine is right by the battery FWIW.
odie241
Thanks Incoop,I will have a look for that inline fuse.Hopefully it was just that fuse
lncoop
I'll cross my fingers and toes for you tonight.
WaterDR
I did that on a Supercharged, 500 hp Mustang once. Very embarrassing. Used a battery with reverse polarity and did nto notice.....DUMB. Anyway, the car went click, and the battery actually smoked. I swapped it out, and it started fine. Never blew a fuse or had any issues.
newbie4life
A lady across the road from us at our local campground, brought her battery from home and stuck it into her camper... backwards. Nothing but lights worked. I went to take a peek, and pulled the cover on the fuse panel. It blew two 40 amp fuses -- swapped the fuses out (and reversed the wiring) and all was fine. Hope this is the case for your friend!!!
lncoop
That's what fuses are for after all. Is anyone else dying to know how it turned out? Hope we get a report this morning.
odie241
Well tore into the wiring harness lastnight didnt see any obvious looking fuses,the closer i got to the motor i found this weird little plastic box with electrical tape around it.I un-wrapped it and low and behold there were two 30 amp fuses in there about a half inch long.I changed both of them and the boat fired right up.Thanks everyone for your input,i knew I could count on you guys.
lncoop
Yay team! Glad your buddy is good to go, and just in time for the long weekend.
EricJRW
Good timing. Glad she's fixed and that nothing more serious got zapped.
Treker57
Ya gotta love all the info and help you can get here, it's great to know that you are not alone when you are felling lost and before you go for a ---HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts not far from the object we are trying to hit.
