Re: front disc brake pads
sassboater,If you've been keeping your brake master cylinder reservoir topped off and the brake pads have worn significantly,consider that the cylinder may overflow by the time you have depressed all of the caliper pistons to install the new pads.You can use a simple syphon bulb to remove some of the fluid from the reservoir between wheels.Might save you a mess to wipe up.<br /><br />Brake fluid level can also serve as a barometer of sorts to indicate pad wear as long as the system has remained leak free.By the time you've had to top off fluid level a couple of times,its likely the pads need attention.
