In the process of removing my old engine from my '89 Glastron I found the nuts on the engine mounts were rusted beyond removal from the studs. So I went ahead and pulled the entire mount from the boat so I could replace it. The current mounts are liquid filled and replacements run $150 each, but I have found newer types of mounts that range from $35-$50 depending on the weight they can hold.
My questions are do I have to stick with the liquid mounts or can they be different and if I go different what weight strength should I get, 350lbs or 500lbs?
