front mounts "stripped"
flargin
89 Bravo 1, 7.4L prior to adjusting the motor, we decided to check if the nuts were 'free' on the adjusting bolts.
Well, no luck, the bolt moved in the mount. We were lucky, the motor is aligned, but...
if we ever need to adjust the front mounts, do you just replace them? or is there a replacement stud, or do you just break them free?
