jack daniels marine
- Joined
- Jun 27, 2012
- 48
1997 DT40
Hi folks.
I bought my first ever boat just last summer. The boat is used only in sea water however my mooring place is about half a mile up a river so the engine gets a good flush with fresh water after every use.
The temperature here has been about 0 - 40deg F ( 5 to -15 C )
I have not sprayed preservation spray in the motor for the winter, Instead I have just started the motor with an oil rich mixture every week or so ( 50:1 oil injection + 50:1 premix in the tank ) just to coat the internal surfaces.
4 weeks back the motor would not start, I assumed the battery was flat so I charged it overnight and the following day the starter only just managed to crank 2 rotations very slowly, the motor jumped into life despite the exceptionally slow starter motor speed. After a couple of minutes I shut it off when I noticed very little water coming out the tell tale hole.
Now 2 weeks later, I used the pull start to "feel" just how much resistance was in the motor , it was too much for me to pull start so I used the el. start and it fired straight away. No water at all out the tell tale hole, just exhaust gas, never seen that before. After using a cleaner wire up the tell tale some dribble began.
So , I'm just wondering now:
what actually happens to the water pump in freezing conditions with the motor tilted back?
should the water pump house drain fully when the motor is tilted back completely out of the water?
Can the rubber impeller freeze onto the rotating surfaces regardless?
If it is frozen, can the the impellor shed rubber peices that block the cooling passages?
Can the impellor drive shaft be damaged by cranking a motor with a frozen water pump?
Is it safe to blow compressed air, 10 bar/ 140psi, up the tell tale hole?
any experiences welcome.
Hi folks.
