Dave Abrahamson
- Joined
- May 8, 2003
- 1,497
Hi Guys,
I have an issue with my 1997 Johnson 115SPL model#J115hxeua.
The motor will barely turn when disconnected from the steering cable. Cable and helm are fine. I've already replace one helm due to stiff steering and I want to avoid that again. I'm trying to pump grease into the steering bracket to no avail. It squeezes out the bottom of the shaft, but won't come up and out through the top by the steering arm. I have pics if needed. I also tapped and put a bolt in the bleed hole that the grease was coming out of in order to try and force it up, but no go.
Anyone had any luck freeing a steering bracket or am I better off finding a donor midsection?
Sorry for the long story, but I wanted to make sure I gave you all the info.
Thank you in advance for any and all suggestions, this is my 1st go to when I have issues. Thankfully not very often.
Happy Thanksgiving all!!
Dave
Dave
