Due to not using it enough, my 115 Mercury (6 Cyl, inline) steering cable seems to be frozen in the lower tube. I have twin cable system and the lower cable appears to be stuck in the tube. I hesitated in "banging away" at the cable end due to fear of distorting the SS connector end.. I unscrewed the inside cable nut (left side of tube, facing engine) and lubed the cable then re connected the nut, hoping that I'll be able to budge this cable when I try this weekend. I'm concerned that there might be an internal connector or screw -in connection inside the tube and want to avoid destroying what may be repairable..... Top cable is fine.... Any ideas ????
