Re: Frozen Water Pump Impeller, 120 Evinrude
Mike, I just finished a water pump rebuild on an '85 John 140 ... the same motor as yours. There's no O ring on the shift rod, only the larger grommet seal you referred to in your post. May be someone left it there on an earlier rebuild. The only O rings in the full kit are the drive shaft top, the larger pump body body to wear plate seal and the inner upper pump housing seal. <br /><br />I also had some trouble removing the impeller. I ended up damaging the wear plate (it had some grooving and needed replacement anyway. I think the plastic cam/key has something to do with the hard to remove thing. In any case, I used a sharp cold chisel between the wear plate and the impeller, but the split the hub sounds like a better way and allows saving the wear plate for reuse if it's any good.<br /> <br /> If there is any groving in the SS pump body liner (in the top), replace it. Any significant grooving in the wear plate or the liner will affect the pump capacity.
