charliegiggles
- Joined
- Oct 19, 2006
- 50
Hi,
I have a 1973 Evinrude outboard model 40354d. I'm not sure what is going on however the engine used to start fine.
I recently put in new points, condensor and spark plug wires thinking this would be beneficial as I bought this motor off someone. Compression is good on both cylinders.
My problem when the plugs are removed and I rotate the flywheel and ground the plugs I'm getting a spark.
After I reinstall the plugs it would appear I no longer am getting a spark on either plug. I say this because if I remove and ground them again attempting to turn the flywheel by hand no spark appears.
I'm stumped as to what is going on and am starting to think the coils are shot or I'm blowing the condensor but really don't know for sure.
If I remove the flywheel unscrew the condensors and reassemble everything all of a sudden I start getting a spark again when I manually ground the spark plug.
Not sure if anyone has experienced a similar problem. I made sure the wires going to the condensor are not being grounded which would prevent a spark from happening.
Any help would be appreciated as I don't want to order parts needlessly.
By the way the spark that I've seen when manually grounding the plug and turning the flywheel by hand does not appear to be very substantial.
Thanks for your help again!
