Hi Guys,
New to the forum but I am having a very frustrating issue that I cannot resolve on my 2003 Yamaha 50 hp TLRB 2 stroke outboard. The engine is on my 17 ft. Carolina Skiff flatbottom boat. We bought the engine backll in 2009 and ran it hard for commercial fishing purposes and it was tremendously reliable, never had one issue. The boat began having issues after one winter of sitting. The problem from the start has been the same, the engine starts up and idles awesome in the yard in neutral, revs up just fine, and seems like it is good to go. Once on the water under load, the engine still starts up and idles fine but immediately when throttled up begins to bog down and almost die unless you bring the throttle back down.
To me this seemed blatantly like a carburetor issue / fuel issue and the engine was not getting the fuel it needed. I've now become an expert on dismantling the carbs and cleaning everything. This spring I'm determined to get the engine back up and running well but it is proving difficult, this is what I've done so far:
1. Replaced all three spark plugs
2. Replaced inline fuel filter inside engine cowling
3. Replaced all fuel lines from tank to engine
4. Installed and replaced new water separator
5. Replaced engine fuel pump
6. Replaced cold start priming mechanism on second carb and rebuilt priming system
7. Bought carb rebuild it, fully disassembled carbs, chem dipped all metal parts over night
8. Rebuilt carbs with new kit
9. Scrubbed and cleaned all jets and parts related to carbs
10. put carbs back together and reinstalled
I blew out both jets and the carbs really looked fully cleaned when I put everything back together and I was feeling certain that the boat would finally run good. I dropped it in today with the priming system set to "oN" and the engine started first turn and sounded good. Went to throttle up, same issue, immense bog into almost die, into throttle down. I also, noticed that when the throttle is in gear, if I put my hand in front of any of the carbs to restrict the air flow , the engine perks up and sounds much better and runs stronger. As soon as I take my hand away, same problem. So, to me it seems that the mix is lean, but I have NO idea how that would be since the carbs aare fully rebuilt. Does anyone have any ideas? Maybe the reed valves? Head gasket? Electrical issue? Powercore? Do the carbs need to be retuned??? Anything would be much appreciated, cheers!
