Fuel before throttle plate?
1990 looper
Hi, I have been restoring a 1990 140 looper. It has been running extremely rich and I assumed it was an ignition problem. More recently I was running it with the air box off. Never did that before. Well, I may have found the problem. Left bank carbs were trickling quite a bit of fuel prior to butterfly plates. The stream seemed to be coming from black bowl vent pipe? Not sure what to call it.
Chris1956
Looks like the fuel is bubbling up thru the main nozzle. I would check the floats, float adjustment and inlet needles for wear.
1990 looper
I was watching a vid of a OMC tech rebuilding plastic carbs. He mentioned not to use the float seat seal ring on plastic bowl carbs. Well, I'm fairly certain
I used it and unknowingly raised my fuel level in the bowls too. Even though I leveled the float with the bowl edge, the thickness of the seal would likely raise the fuel level on the main jet pick tube.
flyingscott
You need to adjust your floats because 3 of the 4 are doing it did you not put the seal in one.
