Fuel capacity on 1993 Eurostar 170?
tinyone
I just purchased a 1993 Starcraft Eurosport 170 F&S o/b. It has a built in fuel tank. Can anyone tell me what the capacity of the tank is? I am trying to verify the fuel gauge is accurate without running it empty. Thanks for your help.
Boland01
Re: Fuel capacity on 1993 Eurostar 170?
I've gor a 1991 Starcraft Eurostar with a 3.0L mercruiser. Mine holds a bout 13 gallons. You can also remove the fuel sender and look in the tank to see how much fuel you have in there. There fill it up and see howm any gallons it takes. if it appeared to be half full and then takes 6 gallons you have your answer.
