Re: fuel check valves
The check valves are in the fuel pump between the pump diaphrams. When you get a fuel pump rebuild kit they usually come with the valves too. Just follow your fuel line under the coweling and when it gets to a square box you have found the pump. There would only be a few screws holding it together ~4 just have a good diagram so you can get it back together right.
