Fuel Connection for 6 hp Sea King
HJE0004
What type of connection is needed to connect fuel line to motor from tank. There is the connection on the motor.
Drowned Rat
Re: Fuel Connection for 6 hp Sea King
It depends on who made your Sea King. Post the model number or year of manufacture and we can tell you.
ahs_mike
Also looking for this info, I want to make sure a 1957 25 HP Sea King has a fuel pump and does not need pressurized duel hoses. Thanks, hope I do not jack your post.
steelespike
I'm pretty sure that is a Chrysler and I think you will find a connector
right here at iboats.under Chrysler/Force motors.
steelespike
Hijacking is bad form mostly because it confuses everthing the original post your post and most of the answers.
Your motor uses a single line system with a fuel pump.
Connector will have two pins a latch pin and a gas line pin.Two line tank has a 3 pin connectior a latch pin an air to tank pin and a gas line pin.
