Re: Fuel consumption of 115 Johnson.
Keep in mind that figure is at wot(wide open throttle)
Could be as low as 3 to 4 gph at a moderate cruising speed.
As I'm allways raving about if you fine tune your setup motor height,trim,
prop selection you can improve your performance Still be about 10gph at wot but you'll have a little more speed so mpg will improve.A careful tuneup wouldn't hurt too.
