Fuel consumption on a 1998 Honda 15 hp 4 stroke
hz
I'm making a short hop in Puget Sound from Port orchard, WA to Des Moines, WA, (about 20nm) My 1976 Catalina 27 will be slung out there and put on a truck. Unfortunately the lift in Port Orchard can't take off my mast and it's not a drop down but Des Moines can.
This is the first time using the boat and outboard. Can anyone give me an idea of how many gal an hour a 1998 Honda 15 hp four stroke would take?
Harris
pvanv
Re: Fuel consumption on a 1998 Honda 15 hp 4 stroke
I'm no Honda expert... but the rule of thumb would be less than 1.5 GPH at WOT. If you drive at hull speed of say 6 knots, for a run time of well under 4 hours, you should theoretically make it on one 6-gal. tank no problem. Of course, possible tides, currents, and headwinds mean that YMMV.
Sea Rider
For a 2 stroke engine 10 and up to 12% of it's rated HP per hour at wot, but being a 4 stroke 35/40 % less at wot on flat seas, no wind conditions. Keeping the sib on plane between 1/2 to 3/4 throttle would be the way to go for fuel efficiency and long cruising.
Happy Boating
