Re: Fuel consumption
2.4 miles per gallon on my 502 Merc, Bravo 1 and 26' ride. That's when cruising and being good.
You are likely near 2.8 with that setup, but the only way to tell your burn rate is to fill it, run it, measure the time and/or distance and go back to the same station and fill the tank. Note the fuel burned.
No one can nail it for you here. You have to do the process above.
We can ballpark it, but this should never be used to plan a voyage. But,
as a buyer, it's safe to say that you can count on less than 3 miles per gallon. So, if you cruise for an hour at your cruising speed (say 38 MPH), then you went 38 miles and burned about 12.6 gallons in that hour. That's being a good boy and just cruising near 40. For comparison, any decent car burns 2 gallons per hour cruising down the highway.
I actually get more like 2 miles per gallon, because a performance boat tends to be pushed a little harder for fun and all that.
