Fuel Consumption
gop711
I have a 1985 18.5 Sunbird with 4.3 litre engine and a OMC outdrive.<br /><br />Could anyone give me a rule of thumb on fuel consumption at 3800-4000 rpm? <br /><br />Thanks<br />Greg
Re: Fuel Consumption
You'll Easily burn $50.00 a Day at those RPMs.......
cuzner
If you keep down around 3000 rpm you will save alot of fuel.<br /><br /> Jim
Spidybot
And some other rules of thumb:<br /><br />Do not carry any unneeded weight<br />Keep the hull & lower unit clean<br />Keep the engine tuned<br /><br />Cruise at the lowest possible speed where the boat is still on a clean plane. This is where the mpg is at it's best: WOT until it planes, then back off on the throttle as much as possible, while maintaining a stable plane.
