kentuckyguy
- Joined
- Jul 1, 2010
- 61
I was wondering what the difference would be in the fuel consumption between a 21 foot pontoon with a 90hp carb 2 stroke verses a 19.5 tahoe with a 4.3 v6.. Both boats are 2010... Thanks
If you "google" the brands you may be able to get a performance report previously published by one of the magazines. But these figures will only be useful as reference, not to be confused with actual use.
SMC is correct, it will be very dependent on how you run them, and how you set them up.
I have the pontoon now... It get about 5-6mpg at wot.. Just wondering what the tahoe would get..
Bad data. Sorry to be black and white, but sumpin' ain't Kosher there . . .I have the pontoon now... It get about 5-6mpg at wot.. Just wondering what the tahoe would get..
Not to hijack the thread, but is it worth measuring MPG on a boat? I've always just figured average GPH because 5 miles with a current, following wind and calm water is so completely different than 5 miles against gusting winds and 3' swells.
boattest generally tries to measure in fairly calm conditions. Anything thrown into the mix is yet another variable that obviously is going to cause issues. Its still worth measuring for comparative purposes if conditions are documented and similar.
I can't explain why this data is wrong, but it also is . . . It just is. There is not a 90 hp OB in existence that uses less than 8 GPH at WOT, and you're claiming less than 4i timed my 90 hp 2 stroke 6 gallons in about 1 hour 45 minuites wot, at 30 mph you do the math 8.6?. did the same test sort of on my 5.8l omc this week i did 20 miles at 30 mph and i only used 4.2 gallons. so i got nearly 5 mpg
I can't explain why this data is wrong, but it also is . . . It just is. There is not a 90 hp OB in existence that uses less than 8 GPH at WOT, and you're claiming less than 4![]()
The value of this Thermal Efficiency relationship is that, by assuming a reasonable TE value (27% - 29%), you can estimate the amount of fuel required to produce a given amount of power.
An excellent BSFC for a well-developed, 4-stroke naturally-aspirated, high-performance liquid-cooled engine at 100% power is in the neighborhood of 0.44 ? 0.45. Claims of gasoline engine BSFC values less than 0.42 at max power tend to be suspect.
So if someone tells you that they have developed a 4-stroke piston engine which, at max power, makes 300 HP on 20 GPH of gasoline, you can quickly calculate a BSFC of 0.39 and a Thermal Efficiency of 34.4%. You should be highly suspicious of such a claim.
