i have a 1983 thunder craft with a 470 merc cruiser when i winterized last year no problems starting i went to put in water this weekend there is no fuel in the line i tried pouring fuel in the carb it starts no problem but i can't get no fuel from the tank so i started from the beginning i pulled the fuel line off the pump poured fuel down the carb motor started pump was sucking so that's not the problem so i put a primer ball on the line i squeeze the ball and i still can't get gas to flow through the line so i made sure line was not cloged no problems there so i kept pouring fuel down the carb but i can't get the fuel to flow from the &$@# tank so i got to the tank the vent is not clogged i took the line off the tank and blew air into the tank it goes in because i can here the bubbles. when i took the line off the tank i got my wife to squeeze the primer ball that i installed and i can feel the suction so now i'm confused, gettin back to the tank i'm not sure if it's original but it's a aluminiun tank it has three holes on top one for pouring gas into it one for the vent and one for gas to go to the carb. now the main question is does the tank have a inline with a check valve or how does the tank work on this make of boat i have never had this problem before and it drove me nuts all weekend luckly i had beer to keep me calm LOL!
