doghunter9
- Joined
- Aug 20, 2008
- 101
Good day guys
OK I got a 94 50hp johnson with vro. About 2 weeks ago i was using my boat, every thing was fine, trailered it home, was sitting for about 1 week, than launched it and I never got out of the harbour, I had to keep priming the bulb(fuel pump Not working?)
Ok, Is it possible that the fuel pump broke in my drive way, or a line is leaking, It is about 3 km to the slip way. so i doubt it crack in transit. also it is about -5 degrees celcius here. my lines have frozen and cracked? I cant fined any leaks.
If i want to switch to standard premix pump is there any troubling doing that. Anybody know the pt # for this pump. I am looking for the ones that have a pulse tube not the one that bolt directly to the crankcase.
I had a old pump of a 84 65hp, I tried that, it was better but not perfect, so i rebuilt it but broke it in the process. So I want to try to get a new one like this but an unsure if it will work? much cheaper then a VRO.
Any input is welcome
Is there any issues with flow if a 65hp pump on a 50Hp?
